Motor is turnigy SK3 4250-350kv
using 12A bench supply set to 16V.
Make dfu succeeded.  Tried a fresh start, erased config
power up with default settings, motor spins approx 90 deg.
In [9]: my_odrive.motor0.error
Out[9]: 22
my_odrive.axis0.config.do_calibration_at_start = 0
In [3]: my_odrive.axis0.config.enable_control_at_start
Out[3]: True
typedef enum {
    CTRL_MODE_VOLTAGE_CONTROL = 0,
    CTRL_MODE_CURRENT_CONTROL = 1,
    CTRL_MODE_VELOCITY_CONTROL = 2,
    CTRL_MODE_POSITION_CONTROL = 3
} Motor_control_mode_t;
my_odrive.motor0.config.control_mode = 2
typedef enum {
    ROTOR_MODE_ENCODER,
    ROTOR_MODE_SENSORLESS,
    ROTOR_MODE_RUN_ENCODER_TEST_SENSORLESS //Run on encoder, but still run estimator for testing
} Rotor_mode_t;
my_odrive.motor0.config.rotor_mode = 1
In [7]: my_odrive.motor0.config.vel_gain
Out[7]: 0.0005000000237487257
(left this at default value)
In [8]: my_odrive.motor0.config.vel_limit
Out[8]: 20000.0
(did not change from default value)
left all other settings at default
my_odrive.save_configuration()
my_odrive.reboot()
motor does not spin on powerup now. good, settings stuck.
In [3]: my_odrive.motor0.error
Out[3]: 0
In [4]: my_odrive.motor0.set_vel_setpoint(1000,0)
(nothing happens)
In [8]: my_odrive.motor1.vel_setpoint = 100
(also does nothing)
confirming settings are still correct
In [5]: my_odrive.motor0.config.control_mode
Out[5]: 2
In [6]: my_odrive.motor0.config.rotor_mode
Out[6]: 1
In [12]: my_odrive.motor0.error
Out[12]: 0
What am I missing to make this motor spin up?
Thanks,
Bill
