ODrive 3.6 56V Encoder Error 512 Calibration Failed
I have bought ODrive3.6ver 56V clone version from Alibaba. I flashed 0.5.6 firmware version. I connected two 0.5Ohm 50W in series for brake resistance. In the M0, i connected 6 inch hoverboard BLDC wheel and
give 24V DC power supply to ODrive 3.6
In the each Hall sensor wires A,B and C is soldered 22nF capacitor to GND.
I configured the my wheel with the following parameters
— axis0 = RIGHT wheel (confirmed wiring location) —
dev0.axis0.motor.config.motor_type = 0 # High Current
dev0.axis0.motor.config.pole_pairs = 15 # 10 # 15 # confirmed via shadow_count measurement
dev0.axis0.motor.config.resistance_calib_max_voltage = 4 # 15 old
dev0.axis0.motor.config.requested_current_range = 25 # 60 need to change
dev0.axis0.motor.config.current_control_bandwidth = 100
dev0.axis0.motor.config.torque_constant = 8.27/16 # 8.27/37.5 #8.27/16.0 #need to change 8.27/16 # 0.2205
dev0.axis0.motor.config.current_lim = 15
dev0.axis0.motor.config.calibration_current = 5
— THE CRITICAL FIX — required for Hall mode on fw 0.5.2+, was missing —
dev0.config.gpio9_mode = GPIO_MODE_DIGITAL
dev0.config.gpio10_mode = GPIO_MODE_DIGITAL
dev0.config.gpio11_mode = GPIO_MODE_DIGITAL
dev0.axis0.encoder.config.mode = ENCODER_MODE_HALL
dev0.axis0.encoder.config.cpr = 6*dev0.axis0.motor.config.pole_pairs # 6 x 10, matches confirmed pole_pairs
dev0.axis0.encoder.config.calib_scan_distance = 150
dev0.axis0.encoder.config.bandwidth = 100
dev0.axis0.controller.config.pos_gain =1 #6 # OLD VALEU1
dev0.axis0.controller.config.vel_gain = 0.02 * dev0.axis0.motor.config.torque_constant * dev0.axis0.encoder.config.cpr
dev0.axis0.controller.config.vel_integrator_gain = 0.1 * dev0.axis0.motor.config.torque_constant * dev0.axis0.encoder.config.cpr
dev0.axis0.controller.config.vel_limit = 3 #10
dev0.axis0.controller.config.control_mode = CONTROL_MODE_VELOCITY_CONTROL # CONTROL_MODE_POSITION_CONTROL # CONTROL_MODE_VELOCITY_CONTROL
dev0.config.brake_resistance = 1.0
dev0.config.enable_brake_resistor = True
dev0.config.dc_bus_overvoltage_trip_level = 29.0
dev0.config.dc_bus_undervoltage_trip_level = 21.0
After successfully configured, I give the following calibration paramters
dev0.axis0.requested_state = AXIS_STATE_MOTOR_CALIBRATION
time.sleep(20)
print(dev0.axis0.motor)
time.sleep(20)
print(f"motor error: {dev0.axis0.motor.error}, is_calibrated: {dev0.axis0.motor.is_calibrated}")
dump_errors(dev0)
if dev0.axis0.motor.is_calibrated:
print(“Starting encoder offset calibration — watch the wheel now…”)
dev0.axis0.requested_state = AXIS_STATE_ENCODER_OFFSET_CALIBRATION
time.sleep(15)
print(f"encoder error: {dev0.axis0.encoder.error}, is_ready: {dev0.axis0.encoder.is_ready}")
dump_errors(dev0)
if dev0.axis0.encoder.is_ready:
    print("Saving...")
    try:
        dev0.save_configuration()
    except Exception:
        pass
    print(" Calibration saved.")
else:
    print("Encoder calibration failed.")
else:
print(" Motor calibration failed.")
I heared beep sound. But wheel is not rotating.
In the terminal window, I got an error Encoder Error 512 and is_ready: False
Unfortunately those clones are pretty flakey / unreliable, especially with halls – we can’t provide support for them, so I’d recommend reaching out to the manufacturer for support. If it was sold as an ODrive product, you can definitely get your money back. In the future, I’d strongly recommend using something such as the ODrive S1, which has much better performance, reliability, and software support as the old v3.6s.
