Hi there!
I wrote a code for the joystick using PyQt 5. It’s very simple, but it’s enough for my task. Now I’m trying to make a deal with Odrive to control the thrusters.
My scheme:
Orange Pi 5 Plus with Ubuntu
Joystick.py
Odrive 3.6
Thruster #1
Thruster #2
Has anyone tried this before?
Here is the code:
from PyQt5.QtWidgets import QWidget
from PyQt5.Qt import *
import sys
from enum import Enumclass Direction(Enum):
Left = 0
Right = 1
Up = 2
Down = 3class Joystick(QWidget):
def init(self, parent=None):
super(Joystick, self).init(parent)
self.setMinimumSize(100, 100)
self.movingOffset = QPointF(0, 0)
self.grabCenter = False
self.__maxDistance = 50def paintEvent(self, event): painter = QPainter(self) bounds = QRectF(-self.__maxDistance, -self.__maxDistance, self.__maxDistance * 2, self.__maxDistance * 2).translated(self._center()) painter.drawEllipse(bounds) painter.setBrush(Qt.black) painter.drawEllipse(self._centerEllipse()) def _centerEllipse(self): if self.grabCenter: return QRectF(-20, -20, 40, 40).translated(self.movingOffset) return QRectF(-20, -20, 40, 40).translated(self._center()) def _center(self): return QPointF(self.width()/2, self.height()/2) def _boundJoystick(self, point): limitLine = QLineF(self._center(), point) if (limitLine.length() > self.__maxDistance): limitLine.setLength(self.__maxDistance) return limitLine.p2() def joystickDirection(self): if not self.grabCenter: return 0 normVector = QLineF(self._center(), self.movingOffset) currentDistance = normVector.length() angle = normVector.angle() distance = min(currentDistance / self.__maxDistance, 1.0) if 45 <= angle < 135: return (Direction.Up, distance) elif 135 <= angle < 225: return (Direction.Left, distance) elif 225 <= angle < 315: return (Direction.Down, distance) return (Direction.Right, distance) def mousePressEvent(self, ev): self.grabCenter = self._centerEllipse().contains(ev.pos()) return super().mousePressEvent(ev) def mouseReleaseEvent(self, event): self.grabCenter = False self.movingOffset = QPointF(0, 0) self.update() def mouseMoveEvent(self, event): if self.grabCenter: print("Moving") self.movingOffset = self._boundJoystick(event.pos()) self.update() print(self.joystickDirection())if name == ‘main’:
# Create main application window
app = QApplication()
app.setStyle(QStyleFactory.create(“Cleanlooks”))
mw = QMainWindow()
mw.setWindowTitle(‘Joystick’)# Create and set widget layout # Main widget container cw = QWidget() ml = QGridLayout() cw.setLayout(ml) mw.setCentralWidget(cw) # Create joystick joystick = Joystick() # ml.addLayout(joystick.get_joystick_layout(),0,0) ml.addWidget(joystick,0,0) mw.show() ## Start Qt event loop unless running in interactive mode or using pyside. if (sys.flags.interactive != 1) or not hasattr(QtCore, 'PYQT_VERSION'): QApplication.instance().exec_()
