When i ran odrivetool, it comes error message like this:
ODrive control utility v0.4.11
/usr/local/lib/python3.6/dist-packages/fibre/shell.py:104: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘import sys’)
/usr/local/lib/python3.6/dist-packages/fibre/shell.py:105: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘superexcepthook = sys.excepthook’)
/usr/local/lib/python3.6/dist-packages/fibre/shell.py:106: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘def newexcepthook(ex_class,ex,trace):\n’
/usr/local/lib/python3.6/dist-packages/fibre/shell.py:109: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘sys.excepthook=newexcepthook’)
Please connect your ODrive.
How can I run normally the ‘odrivetool’ command ?
