If there is no Starpoint I’m assuming I can just wire it directly to the DC- on the board itself.
Is this correct? Just dont want to burn up Odrive.
Looks perfect! If it’s easier, you can just run a tie from the GND in the USB-CAN adapter screw terminal to DC- – it’s essentially equivalent, may just be a bit easier in terms of wiring, up to you!
