Odrive Micro Motor Guide
I’m looking for BLDC motors that allow me to get the maximum torque/output from the Odrive Micro.
My target range:
  • around 3–4 A at 16–24 V
  • these values always refer to continuous current / continuous operation (without overheating)
I’ve already tested several motors, but none of them seem to fit this operating range well.
Current issue:
  • High-KV motors often require significantly more current (20 A+), which causes the controller to overheat.
  • Low-KV motors draw very little current (~1 A), and then the motor itself becomes the limiting factor or starts overheating.
Examples:
4010 74KV Outrunner Gimbal Motor (60T)
→ max. around 1 A continuous
→ Odrive Micro is underutilized
→ motor overheats at higher current
C2830 750KV Outrunner Motor
→ max. around 18 A continuous
→ motor is underutilized
→ controller overheats at higher current
Specific questions:
  1. How can I calculate what KV range I should be looking for?
  2. Are there any lists or community recommendations for motors that work especially well with the Odrive Micro?
  3. Which motors would you recommend to get the maximum performance out of the Odrive Micro?
Hi! It may help to know a bit more regarding the specific application here. Do you have a torque/speed output that you’re targeting?
