Odrive power supply for two d6374 motors
I have the Odrive v3.6 56V connected with one odrive d6364motor and amt102-v encoder.
the power supply that i’m using at the moment is 30V and 5A.
using these parts, i can calibrate correctly the motor using the command:
i can hear the beep motor sound and it turns one round in both directions.
after that, i’m trying to run 50 turns with these commands:
odrv0.axis0.controller.input_pos = 50.0
but it only rotates one time and fail.
the dump.errors return me that:
system: Error(s):
  LegacyODriveError.DC_BUS_OVER_REGEN_CURRENT
  axis: Error(s):
    AxisError.MOTOR_FAILED
  motor: Error(s):
    MotorError.SYSTEM_LEVEL
  DRV fault: none
axis1
  axis: Error(s):
  motor: Error(s):
  DRV fault: none
I suppose that i’m having problems with the power supply. that’s why i’m asking which kind of power supply will work with two d6374? i want to have high speed to create adiabatic movement (3000-5700) and high torque to move 10kg
My first concern is how fast the ODrive is going to try and accomplish 50 turns, using the default PASSTHROUGH input mode is not great for position changes greater than ~1 turn. I would strongly suggest using trajectory control, or streaming positions with filtered position control.
What is the application here? What are the units for
RPM? I’m afraid I don’t fully understand adiabatic movement in this context, as high speed + high torque is going to produce a lot of heat.
I agree that 5A at 30V is probably not enough, but I would need more info to give any more advice.
Thanks for your quick response.
Sorry for my bad explanation, I want to create a traction and twisting machine to rotate a material while is being stretched.
the material is a flexible material. For the stretch part, I only need to use a reducer to get the force i want, but on the twist, i need high velocity. Basically i need to do 50 turns/s and i need the torque to rotate the material these 50 turns.
At the moment i’m using a 30V 5A power supply and with the odrivetool i can’t rotate my motor these 50 turns/s, or maybe i’m not using the correct params and commands.
As you mentioned, i will try the trajectory control to see if i can move my motor as I want. On the other hand, i’m having a look on to a power supply 48V 30A. it’s a little bit expensive but will it work?
thanks,
