Odrive Pro Max rated Fan current
I would like to connect 2+ fans in parallel at the [Fan 12V] and [Fan -] output of the Odrive Pro. What is the max rated current of the fan circuit? How many mA does the 60x60mm 12V fan draw?
We budgeted about 400mA for the fan, theoretically you can draw up to 750mA-1A but that’ll of course cause increased heat dissipation in the DC/DC regulator, so I’d keep it below 500mA if possible. I believe the stock fan is around 200mA, but don’t quote me on that :slight_smile:
