KeyboardInterrupt Traceback (most recent call last)
~\Anaconda3\lib\site-packages\fibre\shell.py in <module>()
----> 1 odrv0.axis0.controller.pos_setpoint = 10000
~\Anaconda3\lib\site-packages\fibre\remote_object.py in __setattr__(self, name, value)
250 if isinstance(attr, RemoteProperty):
251 if attr._can_write:
--> 252 attr.set_value(value)
253 else:
254 raise Exception("Cannot write to property {}".format(name))
~\Anaconda3\lib\site-packages\fibre\remote_object.py in set_value(self, value)
76 buffer = self._codec.serialize(value)
77 # TODO: Currenly we wait for an ack here. Settle on the default guarantee.
---> 78 self._parent.__channel__.remote_endpoint_operation(self._id, buffer, True, 0)
79
80 def _dump(self):
~\Anaconda3\lib\site-packages\fibre\protocol.py in remote_endpoint_operation(self, endpoint_id, input, expect_ack, output_length)
295 self._my_lock.acquire()
296 try:
--> 297 self._output.process_packet(packet)
298 except ChannelDamagedException:
299 attempt += 1
~\Anaconda3\lib\site-packages\fibre\usbbulk_transport.py in process_packet(self, usbBuffer)
96 def process_packet(self, usbBuffer):
97 try:
---> 98 ret = self.epw.write(usbBuffer, 0)
99 if self._was_damaged:
100 self._logger.debug("Recovered from USB halt/stall condition")
~\Anaconda3\lib\site-packages\usb\core.py in write(self, data, timeout)
385 For details, see the Device.write() method.
386 """
--> 387 return self.device.write(self, data, timeout)
388
389 def read(self, size_or_buffer, timeout = None):
~\Anaconda3\lib\site-packages\usb\core.py in write(self, endpoint, data, timeout)
946 intf.bInterfaceNumber,
947 _interop.as_array(data),
--> 948 self.__get_timeout(timeout)
949 )
950
~\Anaconda3\lib\site-packages\usb\backend\libusb0.py in bulk_write(self, dev_handle, ep, intf, data, timeout)
531 ep,
532 intf,
--> 533 data, timeout)
534
535 @methodtrace(_logger)
~\Anaconda3\lib\site-packages\usb\backend\libusb0.py in __write(self, fn, dev_handle, ep, intf, data, timeout)
614 cast(address, c_char_p),
615 length,
--> 616 timeout
617 )))
618
KeyboardInterrupt:
Hope this helps.
Thanks
