I’ve recently purchased a couple 48V ODrives v3.5 that I would like to use to drive 1.5kW BLDC motors.
I installed everything on Windows as instructed but I can’t seem to get the motor to show up in the odrivetool. When I turn the power supply on I get the following entries in the Device Manager
libusb-win32 devices
ODrive 3.5 Native Interface (Interface 2)
Ports (COM & LPT)
USB Serial Device (COM3)
However, when I start anaconda (as administrator) and run odrivetool --verbose, I get the following
ODrive control utility v0.4.1
Waiting for ODrive...
USB discover loop
USB discover loop
ConfigurationValue 1
InterfaceNumber 2,0
EndpointAddress 3
EndpointAddress 131
Please connect your ODrive.
USB device init failed. Ignoring this device. More info: Traceback (most recent call last):
File "C:\ProgramData\Anaconda3\lib\site-packages\fibre\usbbulk_transport.py", line 195, in discover_channels
bulk_device.init()
File "C:\ProgramData\Anaconda3\lib\site-packages\fibre\usbbulk_transport.py", line 54, in init
self.cfg = self.dev.get_active_configuration()
File "C:\ProgramData\Anaconda3\lib\site-packages\usb\core.py", line 875, in get_active_configuration
return self._ctx.get_active_configuration(self)
File "C:\ProgramData\Anaconda3\lib\site-packages\usb\core.py", line 102, in wrapper
return f(self, *args, **kwargs)
File "C:\ProgramData\Anaconda3\lib\site-packages\usb\core.py", line 239, in get_active_configuration
bConfigurationValue=self.backend.get_configuration(self.handle)
File "C:\ProgramData\Anaconda3\lib\site-packages\usb\backend\libusb0.py", line 510, in get_configuration
100)
File "C:\ProgramData\Anaconda3\lib\site-packages\usb\backend\libusb0.py", line 593, in ctrl_transfer
timeout
File "C:\ProgramData\Anaconda3\lib\site-packages\usb\backend\libusb0.py", line 431, in _check
raise USBError(errmsg, ret)
usb.core.USBError: [Errno None] b'libusb0-dll:err [control_msg] sending control message failed, win error: The I/O operation has been aborted because of either a thread exit or an application request.\r\n\n'
If I start the odrivetool --verbose and then turn power on, I get
USB discover loop
USB discover loop
USB discover loop
USB discover loop
InterfaceNumber 2,0
EndpointAddress 3
EndpointAddress 131
EndpointAddress for writing 3
EndpointAddress for reading 131
Connecting to device on USB device bus 0 device 1
In [1]:
and it sits there. Does anyone have a working 48V v3.5 on Windows 10?
Any help is appreciated.
Thanks,
Tom
