Hi everyone,
I’m new to ODrive and was wondering if it’s possible to configure the on-board encoder on the ODrive Pro board on a driven axis with a 23:1 gear ratio from the BLDC motor, for velocity control. Apparently we have successfully performed the motor and offset calibration with the odrivetool, but we get the “missing_estimate” error when trying to arm the system.
For the record, we managed to properly calibrate and drive the system with a previous test, where the onboard encoder’s magnet whas directly driven from the motor axis.
If it’s possible, what parameters should we configure? I found a couple of posts regarding this topic, but I’m not sure if the proposed solutions apply here.
Thanks in advance!
