Hello there,
Firstly thank you so much for making an awesome BLDC driver AND opensouring it!
I have a motor with a 100:1 wormgear attached.
Up until this point I have been making do with position control using just the hall effect, which has been just about good enough for my low precision application due to the high ratio gearbox, but I would like to make it a bit more precise now plus home to a preset position on boot.
So I’m attempting to modify the firmware (main branch) to allow position control using the motors in built hall effect but also with an absolute encoder on the gearbox output shaft to feedback the true position to pos_estimate. If this is not possible or I should be going about this in a different way then please let me know.
I have a AMT232B working and can see its position in odrivetool as axis0.encoder.pos_abs.
I added a new encoder mode (260) and spliced the hall effect control into it, plus made it so that only pos_abs was updated by the AMT232. The other control variables are still updated by hall effect only.
All seems fine (both hall and AMT232 positions being updated) until I try to move to a new position which results in:
MOTOR_ERROR_CONTROL_DEADLINE_MISSED
Seems there is a conflict in the timing for the two modes combined? But I get a bit lost on trying to separate them out and I found that they both have comments saying that they probably shouldn’t be being updated where they currently are.
In low_level.cpp:
417 - // TODO: this is out of place here. However when moving it somewhere
// else we have to consider the timing requirements to prevent the SPI
// transfers of axis0 and axis1 from conflicting.
// Also see comment on sync_timers.
if((current_meas_not_DC_CAL && !axis_num) ||
(axis_num && !current_meas_not_DC_CAL)){
axis.encoder_.abs_spi_start_transaction();
467 - // Prepare hall readings
// TODO move this to inside encoder update function
axis.encoder_.decode_hall_samples();
Sorry for the essay!!
Any suggestions much appreciated.
There are many threads about doing similar things with 2 encoders, but none I can see with hall effect and encoder.
