Pole pair mismatch issue
Oh - note the distance is probably fine, it’s the x/y offset that’s usually problematic. 1-3mm vertical airgap is typically just fine.
Hi solomondg,
I’m getting the same error with a new motor. I tried using harmonic calibration with AMS(AS5047D) but it throws an error saying Invalid State.
I read in the forum that I should update it to devel firmware?
I’m sorry for the trouble! Thank you !
Hi!
Harmonic calibration is supported in firmware v0.6.11 onward – I’d imagine you’re just running v0.6.10 or earlier. You definitely have to do a firmware upgrade, but no need to upgrade to devel.
Never be! Happy to help.
Hi, Yes, I’m running v0.6.10. I’ll upgrade it to the latest version.
Thank you so much!
Let me know how it goes!
Hi, yes I will keep you posted! Thank you again!
