The chanches are small but the program could fail, so I would take a NC limit switch and put it between the power cable, be sure to take a big one to not lose to much voltage
Greetings Stijn
Greetings Stijn
How are you planning to connect with the Xsim software? Are you going to connect the odrives to your computer or are you going to send it to a raspberry pi for example? Do you have some more information for me about the Xsim software because I havn’t figured that out jet.
greetings Stijn
Hi again Stijn, it is recommended by XSim to use a go between (Arduino UNO will suffice) a lot of people using XSim are using the Ard, as its affectionately known, if you haven’t already XSim is a great place to start.
https://www.xsimulator.net/community/
Regards Jerry
my goal is to connect the simtools direct to ODrive. Have a look to the above video. The motion comes direct from the game engine.
You can use the ODrive arduino lib and connect it through an arduino. But I want to use the ASCII interface and my tests are quite good till now.
Register to xsimulator.net and download the package. It’s for free. You need an addin for every game you want to play. That will cost some money. But for testing you can use the lfs https://www.lfs.net/ sim the addon is also for free.
Greetings / Zennix
Thanks for all the help, I LOVE THIS COMMUNITY
hi,
its me again, how is the project going? I have another question, why is everyone using a carbon tube and not stainless steel or something else?
greetings Stijn
Hi Stijn, how is the project going? mine is slow, waiting on bits
CF vs SS, for me SS was the same price, CF is supposed to be stronger, lighter and looks better
https://www.engineering.com/calculators/beams.htm
and
hope this helps
Regards Jerry.
hi,
thanks for the link, I’ve started the build of the first linear actuator, I’m now waiting on some aluminium
greetings Stijn
Hi all,
here is an update about the weekend work.
The upper rig chassis is welded.
The cardan also. Comes from a Mercedes SLK
Now waiting for:
Greetings / Zennix
hi,
how much did the cardan cost?
greetings stijn
it was a used part from ebay, About 29,- €.
Greetings / Zennix
but you only have one now
this is the main joint between the upper chassis and the base chassis. Every actuator will have an little joint at the bottom and a ball joint at the top.
Greetings / Zennix
hi,
is the cardan your center of rotation then? or?
greetigs stijn
hi,
Ow okay I’m making a 6 dof
greetings stijn
OK, great.
The goal far far away should also be a 6dof. But we are the first using ODrive for that and I want to keep the cost and effort as low as possible if it fails.
Greetings / Zennix
hi
hi that’s also true but normally it should work according to me, am I wrong?
I’m using a 6368 motor so that’s a bit bigger than yours
greetings stijn
Can you share the ODrive case with us?
you can place it here
cheers Stijn
how did you attach the carbon tube to the ballscrew nut?
cheers Stijn
