SPI Encoder (BiSS-C) fails to initialize when DC power is applied first
Setup
  • Controller: ODrive Pro
  • Encoder: Aksim Absolute Encoder (BiSS-C 17bit/16bit, spi_encoder0)
  • Motor: CubeMars GL100
  • Encoder power supply: Supplied from ODrive Pro’s SPI connector
  • Config reference: Absolute Encoder Reference Frame
Background
Configured absolute encoder per official documentation. absolute_setpoints → CLOSED_LOOP_CONTROL worked correctly for a period of time, then the issue suddenly began occurring.
Problem
When DC (24V) is applied, the SPI encoder fails to initialize:
  • spi_encoder0.raw = 0
  • pos_vel_mapper.pos_abs = NaN
  • spi_encoder0.error keeps incrementing
  • NaN persists regardless of how long I wait after DC power-up
The only workaround found: disconnect and reconnect USB once → SPI communication recovers and pos_estimate reads correctly → then applying DC power afterward allows normal motor operation.
Questions
  1. Is there a known issue where the SPI interface fails to initialize properly during DC-only boot on ODrive Pro?
  2. Is there a way to force SPI re-initialization after boot (e.g., via odrivetool command or config flag)?
  3. Is there a recommended power-up sequence or startup delay for BiSS-C encoders powered from the SPI connector?
Interesting – haven’t heard of this issue before. Should just start up / work while powered. What does spi_encoder0.status and spi_encoder0.warning return? Does it work when only connected over USB / no DC voltage applied?
Thanks for the response. Unfortunately, development on this system was paused due to other priorities, so I wasn’t able to run the specific tests you suggested.
Partial answers to your questions
  • I did check spi_encoder0.status and related SPI status fields at the time. Based on those readings, I concluded that the encoder was not completing initialization. I don’t remember the exact values, but that observation was consistent with the symptoms.
  • I also tried rebooting ODrive via CAN Command ID 0x16, but it didn’t consistently resolve the issue:
    • worked occasionally but failed most of the time
  • I’m not sure whether I tried Command ID 0x18 (clear errors) — I plan to test this when I get the chance and will update the thread with the results…
Root cause — identified via a different controller
In the meantime, I encountered the exact same issue on a different controller (Everest XCR) using the same encoder, which helped me identify the root cause.
Workaround (on Everest XCR)
Used the CoE (CANopen over EtherCAT) vendor-specific object 0x217c (Set feedback power supply status) to disable and re-enable the controller’s I/O power during startup — effectively power-cycling the encoder after the controller had fully initialized.
Conclusion
  • I’ve used other BiSS-C absolute encoders without ever encountering this problem
  • Root cause is likely insufficient tolerance in the RD50’s circuit or firmware for CLK-before-VDD power sequencing
  • Choosing a more robust encoder is the best long-term solution
  • That said, it would be very helpful if ODrive provided a way to toggle the SPI connector’s I/O power via firmware or hardware — similar to what 0x217c offers on the Everest XCR. This would allow recovery from encoder initialization failures without requiring a USB reconnect.
Ooh, thanks for the detailed investigation!
Unfortunately there’s nothing equivalent to the Everest’s 0x217c on the Pro. The 5V/3.3V on the feedback connector is always on with no switch in front of it, so there’s no way to power cycle the encoder from firmware, and a soft reboot (CAN 0x16 or odrv0.reboot()) will also not cause the encoder to lose power. One workaround would be a small high-side load switch between the ODrive’s 5V and the encoder’s VDD, with an RC on the EN pin. You could also drive the EN pin from a GPIO on the Pro, so you can toggle it on demand. This could also be easily done with a small PFET or similar.
Though I agree, maybe just finding a better BiSS-C encoder would be easier :slight_smile: it’s always crazy to me how much difference there can be between devices that supposedly all follow the same standard, haha.
