Hi! I’m controlling a BLDC motor in torque mode. Given the specific application on which I’m using this motor, I need to ensure that the motor moves at a relatively low speed for safety reasons. The motor is connected to a cable system (it acts more of less like a brake), whose velocity is imposed by another component on the system. The issue with velocity is that, when the cable is disconnected while the system is running, as the motor doesn’t have an external load anymore, it starts to accelerate and achieves a quite high speed, which can be dangerous.
When I use the vel_limit parameter specified in the documentation, it does reduce the velocity at which the rotor moves, but also reduces the torque output, which is not wanted. I measured the achievable torque outputs for a set of vel_limit values and for the operational torque setpoint I want, the vel_limit is still “high”.
Is there a way to set a limit on the velocity without reducing the effective torque output? Thanks
