Trouble Getting two S1s on one CAN bus with Arduino working
Hi! I’m working to get a multi axis arm working with (for now) two Odrive S1s on a shared CAN bus connected to an Arduino minima. To make things simple I’ve exactly recreated the hardware from the tutorial:
https://docs.odriverobotics.com/v/latest/guides/arduino-can-guide.html
Plugging into the first s1 with my Arduino Minima and transceiver and running the example code from above set to axis 0 works great! If I plug into the second s1 and assign the code to axis 1, it also moves and works great! If I connect the whole can bus up with both s1s powered and run either the code for axis 0 or axis 1 it works great again. Where I’m running into trouble is running both motors at the same time. Would anyone happen to have example code of this? Thanks so much!
Hi! Sorry, just to clarify – did you modify the code to use two ODrives, and you’re having an issue getting it working? Or are you asking if there’s already example code for multiple ODrvies over CAN?
Hey Solomondg! I was modifying the example code but having trouble getting it working for two motors and was hoping there might be an example sketch to work from, but crawling the forums I found this user’s post and it looks like their code works for me! I was able to modify it for my purposes! Thanks!
Hi! Please let me know if my code worked as is? Or you had to modify it to make it work? It was not working for me and i gave up on odrives and started using moteus(they worked right out of the box both with python and c)
If possible can you please share your working code here? Ill try to revive my project.
Thank you.
Great to hear that code worked!
Maybe you could post the last code you had?
Hey! Here’s the code I ran that moved both motors for the first time. I think all I needed to change was the CAN baud rate to match what I had configured on the odrive tool:
#include <Arduino.h>
#include “ODriveCAN.h”
// Documentation for this example can be found here:
// Controlling ODrive from an Arduino via CAN — ODrive Documentation 0.6.11 documentation
/* Configuration of example sketch -------------------------------------------*/
// CAN bus baudrate. Make sure this matches for every device on the bus
#define CAN_BAUDRATE 250000
// ODrive node_id for odrv0
#define ODRV0_NODE_ID 0
#define ODRV1_NODE_ID 1
// Uncomment below the line that corresponds to your hardware.
// See also “Board-specific settings” to adapt the details for your hardware setup.
// #define IS_TEENSY_BUILTIN // Teensy boards with built-in CAN interface (e.g. Teensy 4.1). See below to select which interface to use.
#define IS_ARDUINO_BUILTIN // Arduino boards with built-in CAN interface (e.g. Arduino Uno R4 Minima)
// #define IS_MCP2515 // Any board with external MCP2515 based extension module. See below to configure the module.
/* Board-specific includes ---------------------------------------------------*/
#if defined(IS_TEENSY_BUILTIN) + defined(IS_ARDUINO_BUILTIN) + defined(IS_MCP2515) != 1
#warning “Select exactly one hardware option at the top of this file.”
#if CAN_HOWMANY > 0 || CANFD_HOWMANY > 0
#warning “guessing that this uses HardwareCAN”
#else
#error “cannot guess hardware version”
#endif
#endif
#ifdef IS_ARDUINO_BUILTIN
// See ArduinoCore-API/api/HardwareCAN.h at master · arduino/ArduinoCore-API · GitHub
// and ArduinoCore-renesas/libraries/Arduino_CAN at main · arduino/ArduinoCore-renesas · GitHub
#include <Arduino_CAN.h>
#include <ODriveHardwareCAN.hpp>
#endif // IS_ARDUINO_BUILTIN
#ifdef IS_MCP2515
// See GitHub - sandeepmistry/arduino-CAN: An Arduino library for sending and receiving data using CAN bus.
#include “MCP2515.h”
#include “ODriveMCPCAN.hpp”
#endif //
#ifdef IS_TEENSY_BUILTIN
// See GitHub - tonton81/FlexCAN_T4: FlexCAN (CAN 2.0 / CANFD) Library for Teensy 3.x and 4.0
// clone GitHub - tonton81/FlexCAN_T4: FlexCAN (CAN 2.0 / CANFD) Library for Teensy 3.x and 4.0 into /src
#include <FlexCAN_T4.h>
#include “ODriveFlexCAN.hpp”
struct ODriveStatus; // hack to prevent teensy compile error
#endif // IS_TEENSY_BUILTIN
/* Board-specific settings ---------------------------------------------------*/
/* Teensy */
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> can_intf;
bool setupCan() {
can_intf.begin();
can_intf.setBaudRate(CAN_BAUDRATE);
can_intf.setMaxMB(16);
can_intf.enableFIFO();
can_intf.enableFIFOInterrupt();
can_intf.onReceive(onCanMessage);
return true;
/* MCP2515-based extension modules -*/
#ifdef IS_MCP2515
MCP2515Class& can_intf = CAN;
// chip select pin used for the MCP2515
#define MCP2515_CS 10
// interrupt pin used for the MCP2515
// NOTE: not all Arduino pins are interruptable, check the documentation for your board!
#define MCP2515_INT 2
// freqeuncy of the crystal oscillator on the MCP2515 breakout board.
// common values are: 16 MHz, 12 MHz, 8 MHz
#define MCP2515_CLK_HZ 8000000
static inline void receiveCallback(int packet_size) {
if (packet_size > 8) {
return; // not supported
CanMsg msg = {.id = (unsigned int)CAN.packetId(), .len = (uint8_t)packet_size};
CAN.readBytes(msg.buffer, packet_size);
onCanMessage(msg);
bool setupCan() {
// configure and initialize the CAN bus interface
CAN.setPins(MCP2515_CS, MCP2515_INT);
CAN.setClockFrequency(MCP2515_CLK_HZ);
if (!CAN.begin(CAN_BAUDRATE)) {
return false;
CAN.onReceive(receiveCallback);
return true;
#endif // IS_MCP2515
/* Arduinos with built-in CAN */
HardwareCAN& can_intf = CAN;
bool setupCan() {
return can_intf.begin((CanBitRate)CAN_BAUDRATE);
#endif
/* Example sketch ------------------------------------------------------------*/
// Instantiate ODrive objects
ODriveCAN odrv0(wrap_can_intf(can_intf), ODRV0_NODE_ID);
ODriveCAN odrv1(wrap_can_intf(can_intf), ODRV1_NODE_ID);// Standard CAN message ID
ODriveCAN* odrives = {&odrv0, &odrv1}; // Make sure all ODriveCAN instances are accounted for here
struct ODriveUserData {
Heartbeat_msg_t last_heartbeat;
bool received_heartbeat = false;
Get_Encoder_Estimates_msg_t last_feedback;
bool received_feedback = false;
// Keep some application-specific user data for every ODrive.
ODriveUserData odrv0_user_data;
ODriveUserData odrv1_user_data;
// Called every time a Heartbeat message arrives from the ODrive
void onHeartbeat(Heartbeat_msg_t& msg, void* user_data) {
ODriveUserData* odrv_user_data = static_cast<ODriveUserData*>(user_data);
odrv_user_data->last_heartbeat = msg;
odrv_user_data->received_heartbeat = true;
// Called every time a feedback message arrives from the ODrive
void onFeedback(Get_Encoder_Estimates_msg_t& msg, void* user_data) {
odrv_user_data->last_feedback = msg;
odrv_user_data->received_feedback = true;
// Called for every message that arrives on the CAN bus
void onCanMessage(const CanMsg& msg) {
for (auto odrive: odrives) {
onReceive(msg, *odrive);
void setup() {
Serial.begin(115200);
// Wait for up to 3 seconds for the serial port to be opened on the PC side.
// If no PC connects, continue anyway.
for (int i = 0; i < 30 && !Serial; ++i) {
delay(100);
delay(200);
Serial.println(“Starting ODriveCAN demo”);
// Register callbacks for the heartbeat and encoder feedback messages
odrv0.onFeedback(onFeedback, &odrv0_user_data);
odrv0.onStatus(onHeartbeat, &odrv0_user_data);
odrv1.onFeedback(onFeedback, &odrv1_user_data);
odrv1.onStatus(onHeartbeat, &odrv1_user_data);
// Configure and initialize the CAN bus interface. This function depends on
// your hardware and the CAN stack that you’re using.
if (!setupCan()) {
Serial.println(“CAN failed to initialize: reset required”);
while (true); // spin indefinitely
Serial.println(“Waiting for ODrive0…”);
while (!odrv0_user_data.received_heartbeat) {
pumpEvents(can_intf);
delay(100);
Serial.println(“found ODrive0”);
Serial.println(“Waiting for ODrive1…”);
while (!odrv1_user_data.received_heartbeat) {
delay(100);
Serial.println(“found ODrive1”);
// request bus voltage and current (1sec timeout)
Serial.println(“attempting to read bus voltage and current”);
Get_Bus_Voltage_Current_msg_t vbus;
if (!odrv0.request(vbus, 1)) {
Serial.println(“vbus request failed!”);
Serial.print("DC voltage [V]: ");
Serial.println(vbus.Bus_Voltage);
Serial.print("DC current [A]: ");
Serial.println(vbus.Bus_Current);
Serial.println(“Enabling closed loop control on Odrive0…”);
while (odrv0_user_data.last_heartbeat.Axis_State != ODriveAxisState::AXIS_STATE_CLOSED_LOOP_CONTROL) {
odrv0.clearErrors();
delay(1);
odrv0.setState(ODriveAxisState::AXIS_STATE_CLOSED_LOOP_CONTROL);
// Pump events for 150ms. This delay is needed for two reasons;
// 1. If there is an error condition, such as missing DC power, the ODrive might
//    briefly attempt to enter CLOSED_LOOP_CONTROL state, so we can't rely
//    on the first heartbeat response, so we want to receive at least two
//    heartbeats (100ms default interval).
// 2. If the bus is congested, the setState command won't get through
//    immediately but can be delayed.
for (int i = 0; i < 15; ++i) {
  delay(10);
Serial.println(“Enabling closed loop control on Odrive1…”);
while (odrv1_user_data.last_heartbeat.Axis_State != ODriveAxisState::AXIS_STATE_CLOSED_LOOP_CONTROL) {
odrv1.clearErrors();
delay(1);
odrv1.setState(ODriveAxisState::AXIS_STATE_CLOSED_LOOP_CONTROL);
  delay(10);
Serial.println(“ODrives are running!”);
void loop() {
odrv0.setPosition(10);
delay(100);
odrv1.setPosition(10);
delay(100);
