Hello! I am having an issue attempting to update the firmware of this ODrive Pro from 0.6.9 to 0.6.10. I have tried following the steps from here: Legacy Firmware Update
Whenever I type the command “odrivetool legacy-dfu” as described in step 3, I get the error shown in the attached image
This is my first time trying to use an ODrive so I’m very new to it and am relatively new to programming. I could use some help deciphering this error and how to go about correcting it to upgrade the firmware.
In case it is relevant, I am on Windows 10
*Edit: I managed to fix my problem, I had downloaded using Zadig the libUSB driver which is a prerequisite for updating the firmware through the odrivetool, which didn’t fix anything initially. Then I went into Device Manager, found the driver and updated the driver. After updating it then the firmware update was able to go through
