I’m really interested in these motors. @madcowswe please could you say what’s the mean diameter of the rotor is to estimate the moment of inertia?
Yes, sorry I should have included that in the teardown post, since I did actually calculate it.
The distance of the labelled point from from the rotation axis is 68mm. Using the mass we have from before, we get a MOI of (68mm)^2 * 1516g = 0.00701 kg m^2.
This means that if the motor can put out 10Nm, we can spin it up to 800 rpm in 60 ms!
Nuts!
If you do ever put a custom enclosed motor in the store, I’d base it one of these beasts. Servo motor and epicyclic gearbox manufacturers the world over will close their doors overnight.
Arm design concept
So we are trying to make this thing as cheap as possible while still being quite capable. Therefore, no fancy gearboxes, just a single belt transmission for each axis. Also, to increase the payload capacity, we will be adding counterweights to the reverse side.
The original design inspiration for this was a counterweight balanced floor lamp that I saw at my cousins house. I can’t find a picture of that, so this is the most appropriate design I could find. It is a loading arm for connecting the pipe used to load tankers, so feel free to disregard the nautical terms on the labels.
The above design is fully balanced when there is no payload. We can also change the counterweight mass, or move the pivot points, to fully balance the arm with a specific static payload. If we are going to be picking up and dropping things, i.e. if we have a dynamic payload, we can borrow a trick that is very commonly used in elevators, and that is to over-counterweight the arm (elevator). That is, when the arm is empty, it actually has to work to keep the arm down rather than lift up: this larger counter-weight means we get a higher max capacity.
Very conveniently, a belt drive transmission and the hoverboard motor being quite heavy, means we can neatly let the wheel itself be the counterweight; and we can always add more weight if we need to. This concept so far only shows one axis, but we will be stacking the other axis just like in the marine loading arm concept above.
Unlike the marine loading arm, we wont use cables to connect the outer limb, instead we will use a solid rod like the above ABB IRB-760 palliating robot. This robot has another linkage mechanism (the sets of slightly thinner linkage rods). This is used to maintain the end of the robot in the horizontal plane without any additional active axes. I think I will try to do this also for my design, but I don’t really have a plan of how it will be done just yet. Feel free to provide suggestions.
Getting the torque out of the wheel
Okay so this is the main disadvantage to these hoverboard motors: they are designed to spin a rubber tire on the ground, not coerced into powering robot arms. Nevertheless, here is my plan to try to convince them to do so anyway:
The first thing we need to think about is how to get useful torque out. Lucky for us, on the rotor side we can use the 6 screws that hold the cover plate onto the wheel.
Light blue: main rotor shell, light gray: rotor cover plate, yellow: bearing, dark gray: stator.
On the stator side, as you can see the only thing we have available to hold on to is that shaft with the flat on it. That’s gonna be much more tricky without using machined metal parts. Maybe it won’t work, but we are here to find out.
This is the pulley starfish, it is intended to be 3D printed. Substituting the original screws for the rotor cover with longer ones we can attach it in the 6 locations. The pulley is a for a GT2 profile 5mm pitch 15mm wide belt. The gray ring is for the encoder, which I will talk about at the end of this post.
I think there should be enough material, at least when using solid PETg, to handle a fair bit of belt tension. The underside of the starfish has to be flat to allow sitting on the print bed, otherwise I would have made it fill the original countersinks of the cover plate. We can make some separate filler rings for that I guess.
So here is the part that I am the most worried about, the one that will hold onto the shaft.
It will be made out of printed solid PETg plastic.
It will hold two pieces of 2020 aluminium extrusion that are clamped together with two screws.
The top extrusion will be located against the flat of the shaft to transfer the torque. The belt tension will be pulling the pulley “down” in this view, so the interface to the orange extrusion should be under compression. So there are two things I’m worried about: will the small area to the orange extrusion be enough to handle all the torque, and will the light blue plastic part be strong enough to hold the tension of the belt cantilevered so far out?
Feel free to look around in the Onshape document and let me know what you think. This is the live document that I will be working in, so it things may change by the time you look.
Encoder
These motors have hall sensors, but we need more accuracy than that for this. So we need to install an encoder. A shafted or shaft-fitted encoder is mostly ruled out, since it will be quite annoying and awkward to bolt a flange-and-shaft part to the “outside” face of the motor. Two feasable options are on-axis and off-axis magnetic encoders, since you only have to glue a magnet to the rotor, which is fairly easy.
With an on-axis encoder, we would glue a diametrically magnetized magnet to the only on-axis location that is available, namely the location shown above in bright green. The other option is to use a off-axis encoder in a location ext to a rotating face, such as the location shown in red.
These off-axis encoder magnets are often multi-pole, meaning they show multiple “magnetic” rotations per mechanical turn. The drawback of this is that you don’t get any useful homing functionality from the encoder index pulse. The upshot, however, is that you can make the pole count really high, and get a very high resolution encoder.
Free samples are the best. We will be trying out the AS5311 encoder with a 128 pole magnet ring. The encoder outputs 10 usable bits per pole-pair, so that means we have a 65,536 count/rev encoder. Yes I also didn’t quite believe that number when I first saw it. Incredibly, the cost of these parts are like $10-$15 in single quantity! Crazy. Let’s hope it lives up to the specs.
Not only were the samples free, but they got here from Austria in 3 days. These guys know how to impress a customer.
Cooling
If you look closely at the stator, you can see that it has an airgap all around it, except for the connection to the shaft.
But even there, actually, it’s pretty much air-gapped.
This means that by default, the cooling of the coils will be very poor. I think in the original application there was not so much that could be done since the motors needed to be sealed against water and dirt ingression.
Drillin’ Holes
Let’s get one thing straight, stepped drill bits are awesome.
Yep, looks like some air will get to the stator.
I did a test-print, and it’s starting to look less like a hoverboard wheel and more like… I don’t know what, but not a hoverboard wheel. Looks cool though.
On the other side where there is no starfish, we can make big holes! Next time I would probably put them slightly further out. I doubt it makes a huge difference though.
Since the wheel should only spin a couple of turns, we could even add a fan here. This fan is just for illustration, it is completely the wrong size. Not sure how I would attach one, maybe just glue it?
Also look at direct drive electric bicycles… 48V 35 NM motors…
Do you have a URL for the ebay item?
also take a look at skateboard wheels and scooter wheels
readily available up to 800w
would it make sense to put your belt adapter on the other side of the wheel so you have better access to the shaft?
Also, how about removing the rubber wheel and 3d printing belt drive segments that you glue/screw into the hub?
I had two of these arrive yesterday…
Not sure what to expect in terms of newton meters. 35KV, 35 peak amp with your 48V controller and encoder.
Hm, I think Hobbyking has an error on their spec page. Ohms law dictates that these two statements are mutually exclusive:
- 8.1 ohm phase-to-phase.
- 35A current rating.
Unless you are driving it with 210V power and dissipating 11kW of losses. Maybe they mean to write 3.5A? That would be quite high still, but more reasonable.
Yes bike hub motors should have even higher torque, look at the size of the flux gap diameter of these:
Yes I thought about putting the pulley on the opposite side, but that creates even more leverage. The wheel weighs a few kg, but the belt tension I will need is somewhere between 500 and 1000N.
Putting the pulley at the larger diameter of the wheel itself means I will loose some gear ratio, which is still something I want to maximise.
Hobby Kings specs seam to more for entertainment than anything else
They cant get the hole spacing right in the specs, and the pictures vary within the same product… Most gimbals motors I’ve bought from them didn’t match either the pictures or the specs. Luckily, I was 3D printing/Laser cutting the mounts and the hole size and spacing was arbitrary.
If you want even more torque out of a cheap motor then take a look at the link below. I can’t say for sure that they are direct drive brushless motors but implies so by comparing them to gear motors:
In fact they are definitely whopping great BLDC motors. See here:
https://endless-sphere.com/forums/viewtopic.php?f=31&t=65972
It looks the Star Wars Rebel Alliance logo
Hi, new guy, first post, please bear with me
Why not drill a hole in the center of the rotor “cover”, and replace the shaft with a longer one, thus giving you double sided attachment to the structure of your robot arm?
Best regards
Asle Borgen,
The main reason I want to try the cantilever way is that it would mean there are less steps and easier for someone else to build.
Your suggestion is a good idea and is probably what I’ll try if the original way doesn’t work.
Golden Motor has some decent prices on hub motors as well as larger BLDCs.
I’m sure motor suggestions are great and appreciated, but none of these are as cheap or powerful/low kv as hoverboard motors esp used ones. Cheap defined not only by cost but availability and limited reworking.
I think the topic is great, but I see a couple of motor suggestions that are neither as cheap or as powerful as hoverboard motors :D. I’ve been interested in repurposing a few hoverboard motors for a slightly different project (this year electric wheelbarrow for rough woody terrain, next year maybe e-chair in similar conditions) and am very intrigued by the original hoverboard motor repurposing:-)
Not trying to discourage anyone tho just noticed a couple other motor suggestions and wanted to voice that I think the original plans are very interesting to me and I think going to specialized options may have some benefits but affirming that there is distinct appeal to hoverboard motors.
Hello.
I’m also tring to make robotic arm using brushless motor for electric bicycle.
But I’m trying to do this using the motor Magic Pie 2 https://www.goldenmotor.ca/products/Magic-Pie-Edge-Wheel-Only.html
It has 70 nM torque and 1500 KW, 48 volts. The motor weighs about 10 kg.
Also i have power source MEANWELL RSP-3000-48
I tried to use native controller for electric bicycle like this https://www.goldenmotor.ca/products/BLDC-Motor-Controller-48v2000w.html to drive the motor, but i ran into some limitations.
For example, the native controller behaves strangely at very low engine rpm - It blocks the motor as if it doesn’t understand how the hall sensors are located at the moment.
Or controller turns off when the engine has some load current but rpm is zero for 2 seconds (i think this is for do not burn)
I’m very very interesting in this topic.
It would be great if the ODrive be able to control the engine of such a mass with and such current.
Native controller can not properly control the motor Magic Pie.
Can anyone know which motor from the electric bike will be accurately controlled by ODrive? Because I’m starting to think that the cause might be also in the motor
