I try to use usb connect odrive, but odrive always disappear after sometime.
and python just tell me [ ‘RemoteObject’ object has no attribute ‘axis0’]
like what happend in (Usb communication issue / AttributeError: 'RemoteObject' object has no attribute 'axis0')
I think my usb line is short enough(20cm).
and some times I found my raspberrypi can’t start up with red power light on, when connected 3 odrive by usb. after I unplug two usb, it start up normally.(or power RPI first)
I changed a raspberry pi the issue seems gone.
I don’t know how to make the connection heathy?
this is the dmesg report:
[ 3.966417] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
[ 3.972963] cdc_acm 1-1.2:1.0: ttyACM1: USB ACM device
[ 3.978430] cdc_acm 1-1.3:1.0: ttyACM2: USB ACM device
[ 3.980218] usbcore: registered new interface driver cdc_acm
[ 3.980229] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.988401] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.100858] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.112830] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.113722] usbcore: registered new interface driver brcmfmac
[ 4.365427] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.404732] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 6.368877] uart-pl011 fe201000.serial: no DMA platform data
[ 6.379934] 8021q: 802.1Q VLAN Support v1.8
[ 6.394758] random: crng init done
[ 6.394773] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.662866] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 6.808403] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.808417] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 7.113352] bcmgenet: Skipping UMAC reset
[ 7.208006] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 7.208177] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.247968] bcmgenet fd580000.genet eth0: Link is Down
[ 10.040350] fuse init (API version 7.27)
[ 12.768730] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 13.092637] Bluetooth: Core ver 2.22
[ 13.092711] NET: Registered protocol family 31
[ 13.092719] Bluetooth: HCI device and connection manager initialized
[ 13.092738] Bluetooth: HCI socket layer initialized
[ 13.092750] Bluetooth: L2CAP socket layer initialized
[ 13.092786] Bluetooth: SCO socket layer initialized
[ 13.106454] Bluetooth: HCI UART driver ver 2.3
[ 13.106465] Bluetooth: HCI UART protocol H4 registered
[ 13.106532] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.106728] Bluetooth: HCI UART protocol Broadcom registered
[ 13.384616] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.384641] Bluetooth: BNEP filters: protocol multicast
[ 13.384671] Bluetooth: BNEP socket layer initialized
[ 13.447421] Bluetooth: RFCOMM TTY layer initialized
[ 13.447442] Bluetooth: RFCOMM socket layer initialized
[ 13.447460] Bluetooth: RFCOMM ver 1.11
[ 14.796834] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 181.647178] usb 1-1.2: reset full-speed USB device number 4 using xhci_hcd
[ 181.784930] cdc_acm 1-1.2:1.0: ttyACM1: USB ACM device
[ 181.877107] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 182.017055] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 182.107985] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 182.244690] cdc_acm 1-1.1:1.0: ttyACM2: USB ACM device
[ 268.283097] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 268.422521] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 268.523178] usb 1-1.2: reset full-speed USB device number 4 using xhci_hcd
[ 268.662555] cdc_acm 1-1.2:1.0: ttyACM1: USB ACM device
[ 268.753920] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 268.891046] cdc_acm 1-1.1:1.0: ttyACM2: USB ACM device
[ 406.779104] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 406.928597] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 407.019189] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 407.156487] cdc_acm 1-1.1:1.0: ttyACM2: USB ACM device
[ 518.701779] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 518.840313] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 519.002813] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 519.149158] cdc_acm 1-1.1:1.0: ttyACM2: USB ACM device
[ 876.300922] usb 1-1.2: USB disconnect, device number 4
[ 894.519464] usb 1-1.2: new full-speed USB device number 6 using xhci_hcd
[ 894.659093] usb 1-1.2: New USB device found, idVendor=1209, idProduct=0d32, bcdDevice= 3.00
[ 894.659146] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 894.659172] usb 1-1.2: Product: ODrive 3.6 CDC Interface
[ 894.659199] usb 1-1.2: Manufacturer: ODrive Robotics
[ 894.659209] usb 1-1.2: SerialNumber: 208E368A5550
[ 894.674071] cdc_acm 1-1.2:1.0: ttyACM1: USB ACM device
[ 936.587322] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 936.726445] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 936.817186] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 936.954468] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
[ 937.047044] usb 1-1.2: reset full-speed USB device number 6 using xhci_hcd
[ 937.186503] cdc_acm 1-1.2:1.0: ttyACM2: USB ACM device
[ 1201.508458] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 1201.648163] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 1214.039101] usb 1-1.2: reset full-speed USB device number 6 using xhci_hcd
[ 1214.175663] cdc_acm 1-1.2:1.0: ttyACM2: USB ACM device
[ 1228.367934] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 1228.507417] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
[ 1535.805468] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 1535.943369] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 1536.045771] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 1536.183932] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
[ 1536.275349] usb 1-1.2: reset full-speed USB device number 6 using xhci_hcd
[ 1536.411842] cdc_acm 1-1.2:1.0: ttyACM2: USB ACM device
[ 1724.782406] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 1724.929861] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
[ 1725.022497] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 1725.161520] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
[ 1762.642210] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 1762.791306] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 1762.882710] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 1763.019125] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
[ 1942.909561] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 1943.056963] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 1943.058333] usb 1-1.3: usbfs: process 1703 (Client.py) did not claim interface 2 before use
[ 1943.209566] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 1943.348860] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 1943.449484] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 1943.589163] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 1955.899300] usb 1-1.2: reset full-speed USB device number 6 using xhci_hcd
[ 1955.999122] usb 1-1.2: device descriptor read/64, error -32
[ 1956.219126] usb 1-1.2: device descriptor read/64, error -32
[ 1956.439164] usb 1-1.2: reset full-speed USB device number 6 using xhci_hcd
[ 1956.539155] usb 1-1.2: device descriptor read/64, error -32
[ 1956.759818] usb 1-1.2: device descriptor read/64, error -32
[ 1956.979155] usb 1-1.2: reset full-speed USB device number 6 using xhci_hcd
[ 1956.979377] usb 1-1.2: Device not responding to setup address.
[ 1957.199868] usb 1-1.2: Device not responding to setup address.
[ 1957.418934] usb 1-1.2: device not accepting address 6, error -71
[ 1957.518942] usb 1-1.2: reset full-speed USB device number 6 using xhci_hcd
[ 1957.519144] usb 1-1.2: Device not responding to setup address.
[ 1957.739297] usb 1-1.2: Device not responding to setup address.
[ 1957.958937] usb 1-1.2: device not accepting address 6, error -71
[ 1957.963522] usb 1-1.2: USB disconnect, device number 6
[ 1958.059395] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 1958.199128] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
[ 1958.202402] usb 1-1.1: usbfs: process 1703 (Client.py) did not claim interface 2 before use
[ 1958.289198] usb 1-1.2: new full-speed USB device number 7 using xhci_hcd
[ 1958.399089] usb 1-1.2: device descriptor read/64, error -32
[ 1958.619071] usb 1-1.2: device descriptor read/64, error -32
[ 1958.839560] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 1958.978701] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
[ 1959.069003] usb 1-1.2: new full-speed USB device number 8 using xhci_hcd
[ 1959.169507] usb 1-1.2: device descriptor read/64, error -32
[ 1959.389119] usb 1-1.2: device descriptor read/64, error -32
[ 1959.509125] usb 1-1-port2: attempt power cycle
[ 1959.609464] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 1959.746993] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
[ 1960.168959] usb 1-1.2: new full-speed USB device number 9 using xhci_hcd
[ 1960.169158] usb 1-1.2: Device not responding to setup address.
[ 1960.389036] usb 1-1.2: Device not responding to setup address.
[ 1960.608896] usb 1-1.2: device not accepting address 9, error -71
[ 1960.708912] usb 1-1.2: new full-speed USB device number 10 using xhci_hcd
[ 1960.709118] usb 1-1.2: Device not responding to setup address.
[ 1960.929103] usb 1-1.2: Device not responding to setup address.
[ 1961.149030] usb 1-1.2: device not accepting address 10, error -71
[ 1961.149508] usb 1-1-port2: unable to enumerate USB device
[ 3123.246761] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 3123.384036] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
[ 3123.476846] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 3123.614217] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
[ 3135.149080] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 3135.286219] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 3135.386769] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 3140.576935] usb 1-1.1: device descriptor read/all, error -110
[ 3140.677089] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 3140.814438] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
[ 3217.286863] usb 1-1.1: reset full-speed USB device number 3 using xhci_hcd
[ 3217.426514] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
[ 3217.517890] usb 1-1.3: reset full-speed USB device number 5 using xhci_hcd
[ 3217.664246] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
