Error_brake_resistor
When I try to increase the vel_limit to 210000 to 250000 the motor coast to a stop and I get the following errors
ERROR_INVALID_STATE
ERROR_BRAKE_RESISTOR_DISARMED
ERROR_MOTOR_DISARMED
the odrv0.config.brake_resistance is 2.0
Is there any way to stop this from happening and to increase the speed?
Thank you in advance for your help.
I’m not completely sure, but I think you are saturating the brake resistor. What bus voltage are you running, what settings for current_lim, and what motors are you using?
We will be adding better error messages for brake resistor saturation, it’s already on the devel branch, and should be available soon.
@madcowswe I get this same issue, what do you need for me to do to help you solve this?
I posted here: ERRORS: Axis: 0x30 Encoder: 0x0 Motor: 0x40
but will happily close that thread to continue this one.
I get the following errors when I spin the motor up. Once it hits a specific point, it trips and coasts to a stop. Then the errors for BRAKE_RESISTOR_DISARMED cannot be cleared.
Why is this happening and what can I do to stop it… am I going to fast?
motor.config.current_lim = 50.0
controller.config.vel_limit = 1000000.0
** I am new to this, so please bare with me on this :slight_smile:
[ axis ] => ERROR_BRAKE_RESISTOR_DISARMED : the brake resistor was unexpectedly disarmed
[ axis ] => ERROR_MOTOR_DISARMED : the motor was unexpectedly disarmed
[ motor ] => ERROR_BRAKE_CURRENT_OUT_OF_RANGE :
This is the latest information on this problem.
It’s becoming quite a problem for the development I’m involved in.
@Neil_FV Thanks for the info.
Are there any “Best” settings you have found for this. I am fine limiting my project for now while this is being solved. This is my first robotics project and I am way over my head here on the electronics side. Any help is appreciated.
I’m using a standard hobbyking 149kv motor, 46v and a limit of 75 amps
should I put another resistor in series?
… anybody have any ideas on this?
I posted a solution here:
